AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Export/Import Thematic Rules
2 REPLIES 2
702 Views, 2 Replies
I set the thematic rules for a connected data (example .shp file) in the style editor, can I use this thematic rules automatic for other connected data? This other connected data (other, slightly modified .shp file) have same values as the first.
(I think this so, as in arcview the .avl file, or in arcmap the .lyr file)
= Can I export, and than import the thematic rules?
2 REPLIES 2
I'm having the same problem, how can we export only thematic rule?  I know we can export .layer file for Civil3D/Map3d that exports the thematic rule but it exports the source file data location.  I need to apply thematic rule on a snippet of a large data source.
parkr4st
”Boost
