OK, this is a new problem. I've always been able to insert SID files into
Map 5... until now.
When I try to insert SID images now, even only one little 5MB aerial image
file, I get:
Exception in C:\Program files\Autodesk Map 5\AcMapRastEx10.arx ARX Command
Unhandled Exception C0000005 (Access Violation Reading 0x0000) at address
33FDDEABh
(Strangely enough, my "old" LizardTech MrSID standalone viewer can't open
these, either. I get an Access Violation error in there, too).
Is this particular dataset of SID images too new for Map 5 to handle?
Is there an updater for Map 5 to be able to insert newer SID files?
Any help would be appreciated! Thank you.
