AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Esri Shape file to topology
2 REPLIES 2
kurios-cad
777 Views, 2 Replies
xxxxI have imported an ArcView shape file into a drawing.
THe dat is a polygon with the object data associated in a centroid(?).
How do I create a polygon topology using this data. I have not had any luck with what I am tried.
Thanks Tim
P.S. Sorry about my previous message, I accidently hit the wrong key.
2 REPLIES 2
in reply to: kurios-cad
Tim,
What happens is that when you import an ESRI
polygon shape file is that each polygon has its complete, closed polyline (This
is how Arc-View operates).
In Map you need to "Clean Up" your drawing so that
you will have only one object for each boundary. This involves using several of
the clean-up commands and eventually running "Create Topology".
Good luck,
Arad
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
xxxxI
Thanks Tim
key.
Make sure you save your object data to centroids
before cleanup. Use the Mapcreatecentroids command.
Tim,
(This is how Arc-View operates).
that you will have only one object for each boundary. This involves using
several of the clean-up commands and eventually running "Create
Topology".
Good luck,
Arad
xxxxI
Thanks Tim
key.
”Boost
