AutoCAD Map 3D General Discussion
Active Contributor
Lyonstp
Message 1 of 4 (114 Views)
Errors when querying a drawing
114 Views, 3 Replies
07-19-2012 06:28 AM
I'm trying to change the coord system on a drawing. I've gone through the steps properly but when I try to query the drawing content (query all) i get the following "message": "some entities from (drawing name) can't be queried"
these "entities" appear to be most all of the drawing content less a few polylines. Is there any way to fix this?
Alfred.NESWADBA
Message 2 of 4 (115 Views)
Re: Errors when querying a drawing
07-19-2012 06:33 AM in reply to: Lyonstp
Not all entities can be queried with this functionality, at least only plane AutoCAD-geomtry can be transfered.
Not allowed are all geometry-types from any vertical products like ACA, MEP, Civil3D, .... and also objects referenced by FDO with Map3D.
It now depends on the projection-modifications that are done between your source and your destination coordinate-system. If you have the chance to use command _ALIGN to move/rotate/scale your "invalid" objects then you can use this command.
The other option is not really an option: explode all objects that are not querable back to plane AutoCAD geometry.
- alfred -
Alfred NESWADBA
Active Contributor
Lyonstp
Message 3 of 4 (112 Views)
07-19-2012 06:50 AM in reply to: Alfred.NESWADBA
hmm, i may have to resort to exploding the C3D objects then. Is there another way to go about changing the coord system on a C3D drawing, one that has C3D objects in it?
Basically i have a C3D drawing that was done in a local coord system (one thats recognized by C3D) and I need to convert it to a state plane coord system. the tutorial says to go about it by creating a drawing in the new (state plane) coord system, attaching the original drawing and then running a query on the original attached drawing. it was going smoothly until i ran into the problem of not being able to query most of the objects in the drawing.
Not really sure where to go from here
Alfred.NESWADBA
Message 4 of 4 (110 Views)
07-19-2012 07:14 AM in reply to: Lyonstp
You may try to use the LandXmlExport and -import functions to export your current data and import it into a new drawing with another coord-sys (never tried that).
And yes, Civil3D-drawings do have their coord-sys-setting, look e.g. into dialog for the drawing-settings (>>>details<<<)
- alfred -
Alfred NESWADBA
You are not logged in.
Ask the Community
