AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Errors when querying a drawing
3 REPLIES 3
327 Views, 3 Replies
I'm trying to change the coord system on a drawing. I've gone through the steps properly but when I try to query the drawing content (query all) i get the following "message": "some entities from (drawing name) can't be queried"
these "entities" appear to be most all of the drawing content less a few polylines. Is there any way to fix this?
3 REPLIES 3
Alfred.NESWADBA
Not all entities can be queried with this functionality, at least only plane AutoCAD-geomtry can be transfered.
Not allowed are all geometry-types from any vertical products like ACA, MEP, Civil3D, .... and also objects referenced by FDO with Map3D.
It now depends on the projection-modifications that are done between your source and your destination coordinate-system. If you have the chance to use command _ALIGN to move/rotate/scale your "invalid" objects then you can use this command.
The other option is not really an option: explode all objects that are not querable back to plane AutoCAD geometry.
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
in reply to: Alfred.NESWADBA
hmm, i may have to resort to exploding the C3D objects then. Is there another way to go about changing the coord system on a C3D drawing, one that has C3D objects in it?
Basically i have a C3D drawing that was done in a local coord system (one thats recognized by C3D) and I need to convert it to a state plane coord system. the tutorial says to go about it by creating a drawing in the new (state plane) coord system, attaching the original drawing and then running a query on the original attached drawing. it was going smoothly until i ran into the problem of not being able to query most of the objects in the drawing.
Not really sure where to go from here
Alfred.NESWADBA
You may try to use the LandXmlExport and -import functions to export your current data and import it into a new drawing with another coord-sys (never tried that).
And yes, Civil3D-drawings do have their coord-sys-setting, look e.g. into dialog for the drawing-settings (>>>details<<<)
- alfred -
Alfred NESWADBA
”Boost
