Greg,
running the Map > Import command, when having selected the coverage to
import, Map brings up the Import dialog box. In this dialog all coverage
components are listed.
You can see a column called 'Data' with a default value of . Pick
the of the Input Layer that contains the attribute data. A button
with 3 dots (...) becomes visible. Pick this button, it brings you to
the 'Attribute Data' dialog box where you can select the fields to
import.
When the import was done the selected attribute data should be linked as
object data to the objects.
Marion Pietsch
WW Support & Services
Autodesk GIS Product Support
"Greg J. Zartman" wrote:
> Has there been some kind of a change to the import utilities since version
> 3.0? When I try to import an ARCINFO coverage into map4.5, none of the
> attribute data is transferred to object data. In fact, the import utility
> doesn't even give me the option to specify object data.
> Thanks
> Greg J. Zartman
