Brian, you are welcome,
I am learning constantly my-self.
There quite a few more very handy tools in Map that can help many AutoCAD
users.
My favorite is the Report mechanism that can help generate any kind of BOM
with ease and speed.
About your question. The Thematic tab in Map Project Workspace is the wizard
for creating "Thematic" maps. The word thematic comes from theme and refers
to a certain subject or property that you want to emphasize in your map. For
example, a map that has all road polylines colored according to repair
status. Now, if you have the repair information attached in an external
database then you will not be able to show it an a regular AutoCAD plot.
With Map you can create a Thematic map that will color each object according
to its attached non-graphical information.
I hope my explanation was helpful,
Arad
"Brian Hailey"
wrote in message
news:2F687A66769A5032D7B5E30C73755A8E@in.WebX.maYIadrTaRb...
> Thanks for the pointers, Arad. I'm constantly learning. From what I've
> seen, most of the GIS applications of Map are not beneficial for the
common
> civil engineer (still not quite sure what a thematic is) but since Land
> Development Desktop is built on Map, I'll use as many as will benefit me.
> Brian
> "Arad Gazit" wrote in message
> news:A8948D374DAB8513D70487F3A7516EF5@in.WebX.maYIadrTaRb...
> > Brian Hi,
> > I think that the idea behind the "Query thing" is that you organize your
> > data in such a way that you can always get your queries to achiev the
> wanted
> > outcome.
> > This means, for example, that different kinds of data are on different
> > layers. Large datasets are usually broken up either by "Layer" (In the
> broad
> > sense: Roads, Pipes, etc.) or "Tiled" (One kind of data broken up
> > geographicaly).
> > Furthermore, setting up your Project (Drawing set) can be done in a way
> that
> > helps activating or deactivating different parts of a project by
modifing
> > only one drawing (This is done by nesting the attached files).
> > One more point. When saving your queries to external query files, you
are
> > given the option to keep the list of ACTIVE drawings. This can help you
> run
> > a specific query with the exact files needed.
> > Arad
> > "Brian Hailey" wrote in message
> > news:CDDB8C5B2AFAFFD5388920ED7E5EBED5@in.WebX.maYIadrTaRb...
> > > Neil,
> > > That's what I thought. Oh well, I'll get this query thing figured out
> > > someday.
> > > Brian
