The program doesn't know what unit you're drawing in. Any settings as far as coordinate systems or INSUNIT variables only come in to play when doing conversion. Your parcels look 1/3 too small because of the real world difference between meters and feet.
You can use the excellent method that Murph suggested. But if you only have a few to do, you could just draw the parcels and then scale them by 3.280833333334. That will put your meters in US Survey feet. You wouldn't use this method if you had geodetic coordinates for the parcels. But since you just have deeds you don't have to worry. There will be error anyway because the deeds are usually measured in Ground distance.
Allen
Allen Jessup
CAD Manager - Designer
