Hey Neil (and Max),
While some might quibble with your comment about Map not being a user
friendly GIS tool, I'd recommend using the Map Annotate feature (in Map 6
and 2004) that allows you to add attribute text to objects without having to
query things and use property alteration. You can also view object data inn
a simpler way via the Object Property Manager (OPM) aka Property Palette in
6 and 2004 also.
Cheers,
David
"Neil Wilson" wrote in message
news:3fdf7431$1_2@statler...
> When you imported the data you had the option of creating object data.
This
> object data is associated with your imported elements, but to access it
you
> must use the "edit object data" in the map pull down menu. Using the "edit
> object data" dialogue you can pick an element (line, point, etc) and view
or
> edit the database information associated with it.
> If you want to create text in your drawing from this object data, you must
> open a new blank drawing, attach the drawing that has your imported data,
> and perform a query with the Alter Properties feature activated. Using
alter
> properties, you can tell Map to create text elements from the object data
> associated with the lines, polygons, and points in your source drawing.
> This is certainly not an intuitive process, which is why Map is not a user
> friendly GIS tool. You would do well to read about altered property
queries
> in the help system for Map, as well as how to import Shape files and
> coverages.
> "Max Lorenz" wrote in message
> news:3fdf33cd$1_7@statler...
> > I am trying to get USDA Soil Survey information into AutoCAD.
> > I went to the Soil Survey Geographic Database and downloaded all the
files
> > for Dekalb County, Georgia:
> > cov.zip --> Arc/Info Coverages
> > ga089.me2 --> Metadata text file
> > out.zip --> Arc/Info Export File
> > readme --> Readme text file
> > shp.zip --> ArcView Shape file
> > tab.zip --> Attribute Data
> > I ran MAPIMPORT on the Arc/Info Coverages and pulled in all the
linework,
> > and nodes, but for the life of me, I can't seem to get the text soil
name
> > descriptions to come in.
> > Come to think about it, I have never been able to get text to come in on
> the
> > imports.
> > Is there somebody that can tell me what I have to do to get the text to
> come
> > in?
> > I have pored over the help files, and I don't seem to be having much
luck
> > finding this stuff in the tutorials.
> > Thanks in advance,
> > Max J. Lorenz II
> > TerraNova Engineering, Inc.
