AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Downloadable Help File?
2 REPLIES 2
27thofnever
391 Views, 2 Replies
Is there a way to download the Map 3D 2013 help file?  A user has a computer that can't, for security reasons, be  connected to the internet.
Thank you!
2 REPLIES 2
philip.s
in reply to: 27thofnever
Welcome to the community Jason!
I'm not sure if this is relevant to Map 3D, but on other AutoCAD verticals you can go to Options -> System tab -> and uncheck "Access online content when available", which will then cause the in-product help to look on the local drive for help content.
The specific location of the local content can be found and consequently opened from the Options -> Files tab.
Can you let me know if that works?
27thofnever
in reply to: philip.s
Thank you, sir!  I believe that will work perfectly.
”Boost
