AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Displaying Parcel Object Data as a table in the drawing
5 REPLIES 5
stacy.dunn
531 Views, 5 Replies
I have a drawing created from importing shp files.  The polylines have object data attached.  I would like to put this data into a table to display it in the drawing.
Is there a way of doing this?  Do I need to export the OD to an external database and then link that to a table?
thanks
Stacy
Stacy Dunn
5 REPLIES 5
antoniovinci
in reply to: stacy.dunn
I fear you cannot directly, sir.
But, if you open up the .DBF file of the shapeset into a spreadsheet (e.g. the free Libreoffice) you could copy the whole table and paste it in Autocad as OLE object.
parkr4st
in reply to: antoniovinci
command  DATAEXTRACTION
http://www.youtube.com/watch?v=glziAlsuAX8
dave
stacy.dunn
in reply to: parkr4st
Dave,
Where in the Dataextraction wizard, do you find GIS object data that is attached to an entitiy?  I am only able to locate attribute and object properties.
Stacy Dunn
save your drawing with the object data and close it. Create a new drawing, use command _ADEDRAWINGS to attach the object-data-drawing, use command _ADEQUERY to query data from the source drawing and use option "Report" to create a listed output. You have now an ascii-file with the object data content ... what ever you like to do now with that 😉
Good luck, - alfred -
Alfred NESWADBA
(not an Autodesk consultant)
parkr4st
in reply to: Alfred.NESWADBA
I'll stand corrected on that one.  Even though the help file directions clearly state "object data". 😞  @AD Time for someone to rewrite the directions in help?
or better yet make the routine so it will take the object data to a table.  wish list item?
my bad. please foregive.
dave
”Boost
