AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Deleting or remove a vertex from a map feature
2 REPLIES 2
1147 Views, 2 Replies
Hi!
Does anyone know how I can delete/remove a vertex from a map feature? I have a shapefile that I have connected to and I need to alter some of the geometry of a few of the parcels. I can move the vertices around and delete the entire feature, and check in and out with no problem... However I cannot delete or remove an unwanted vertex. I am kind of new to this...
Thanks!
2 REPLIES 2
hence_the_name
not sure if this is dependent on your map version. I use Map 2012 and can modify a feature similar to modifying a pline using pedit. I can insert a new vertex and delete an existing one.
As I don't have the english version - I click on the SHP feature (polygon) and open the context menu which has an option called "modifying polygon" (or something similar in english). Via this options I have further options such as "modify vertexes" which includes "insert" and "line". "Line" is for removing - have a look at AutoCAD PEDIT command. LINE option there works the same as here.
Rob
http://raumpatrouille3d.blogspot.ch/
parkr4st
in reply to: hence_the_name
select the feature, grab the point you want to delete, drag and drop on an adjacent point & check in
dave
”Boost
