Hello everybody,
at the moment i am working on an connection between a *.sdf Model in AutoCAD Map 3D 2012 and a MS-Access Table (Attribut Data).
I connected the MS-Access table in my MAP Project by the FDO connection (ODBC).
after this, I linked the imported MS-Access table to the Layer Data-Table.
The Problem is: I can´t Edit the Data. All the Data of the imported MS-Access table is lowlighted and i cannot edit it.
At the end i´d like to configure a connection between access an AutoCAD Map. So when i edit a data field in AutoCAD Map, it should be updated in the MS-Access table to and vice versa. (Read/ Write)
Is this possible in AutoCAD Map 3D 2012?
Maybe someone of you can help me
Thanks a lot in advance!
JB0001
