Hello all,
I'm having trouble connecting to data in Civil 3D 2013. Data connect appears to make the connection, but when I click the "Add to Map" button, all the check boxes on my data get unchecked and nothing is added to the drawing.
I first noticed this using the Basejump add on, but it now happens any time I attempt to connect to any data.
No error messages appear. Thoughts?
Many thanks,
Andrew
Hello
Are you speaking of the Basejump Autodesk Labs FDO Driver ?
Which is not included in MAP/CIVIL 2013 ...
Bye, Pat
Patrice BRAUD
Hello
OPTIONS / 1st Tab "Files ..." / 1st Folder "Support ..."
Have you this folder :
C:\Program Files\Autodesk\AutoCAD Civil 3D 2013\bin\FDO
in your Support folders ?
just after the 6 (about) standard folders for AutoCAD ...
Bye, Pat
Patrice BRAUD
mmm .. seem to be having the same problem. Civil 3d 2013.
I have this support path. But i just can't add any images using raster connection. I can MAPIINSERT, however that wont change the coord system on the fly!
Any ideas
Kapanther
I'm also have this problem in C3d 2016. Am unable to connect raster image (aerial photo) tho others within my company with same install have no issues. Has there been any resolution to this?
