AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
DWK Files Does AutoCAD MAP 3d - Civil 3d use them anymore?
3 REPLIES 3
640 Views, 3 Replies
As I understand it... there is a feature in Civil 3d where a user can 'Check-Out' down to the object level certain entities for editing. When this happens a DWK file created.
Does Civil 3d or its MAP... use DWK anymore... does it still have this Checking Out objects creating a DWK file?
When was the last time it was used?
3 REPLIES 3
Alfred.NESWADBA
Yes, it does, whenever you have attached a drawing via the Map 3D function _ADEDRAWINGS and you do some _ADEQUERY requests.
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
in reply to: Alfred.NESWADBA
Is this DWK the case for AutoCAD MAP 3d (Civil 3d) 2015 product line?
I am a little confused here... is AutoCAD MAP and Civil 3d one and the same software?
Alfred.NESWADBA
No, it's not the same, but Map 3D (without Industry Models) is included within Civil 3D. So most of the Map 3D functionality is also available in Civil 3D.
Or with other words: Civil 3D extents the Map 3D functionality with the aibility to design surfaces, do road design and some other civil engineering tasks.
- alfred -
Alfred NESWADBA
”Boost
