Hi Shawn,
Use LDD 3. It does a good job on shaded relief and imports. You can directly
create a terrain model from a DEM file without needing to import it first.
Cheers,
david
"Shawn McDonald" wrote in message
news:4F092874634AF3B1F5DB829ACE600B85@in.WebX.maYIadrTaRb...
> Can Map be used to create shaded relief maps? I've done this with
ArcView,
> but can't find any reference to 'shaded relief' in Map's help files. If
> this is supported by Map, is it referred to as something else? It seems
> this would be a Map function, but I have LD3 available for use as well.
> Using Map5/LD3/XPpro. Thanks-
> Shawn
