AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Curve solver
4 REPLIES 4
tommcgtx
2017 Views, 4 Replies
Curve solver
I was recently using Civil 3D 2010, but am now using Map 2007, ( and this was a promotion?). I am looking for a "Curve Solver", and saw in the discussion groups that one was made by Peter Funk, and even improved upon by Laurie Comerford. I cannot find either one, and wodered if anyone knew exactly where to find them. They mention that it can be downloaded, but I cannot find the areas they refer to. If someone could, it would be helpful to post a direct link to the web page either program is found on.
4 REPLIES 4
cjneper
in reply to: tommcgtx
Do the attached lisp programs do what you are looking for?
tommcgtx
in reply to: cjneper
Yes, that work's! I noticed that you can only input angles in decimal for (instead of DDMMSS). That's ok, but it would be nice to be able to input Degrees, Minutes, Seconds.
ginopalomo
How do you run it?
antoniovinci
in reply to: ginopalomo
Command: _APPLOAD
”Boost
