AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Creating contours from LiDar data
1 REPLY 1
lefty1484
1669 Views, 1 Reply
I'm trying to create countours from lidar data.  I've been able to bring in lidar data and generate a solid surface in Autocad Map.  However, I have not been able to figure out how to create a usable surface out of this.  Is there anyway to export this data to a .grd or .tin file?  I am using Autocad Map 3D 2015 with Carlson Civil Suite 2015.  I have used Autocad for the past 11 years and just recently started a new job that uses Autocad Map, so I'm still trying to adjust.  Any help would be greatly appreciated.  Thanks!
1 REPLY 1
gluckett
in reply to: lefty1484
If you have a surface attached, you can create contours in the Display Manager.  Just right-click the surface layer and choose Create Contour Layer.
”Boost
