AutoCAD Map 3D General Discussion
Active Member
MWRA
Message 1 of 4 (283 Views)
Creating and using dwg seed file
283 Views, 3 Replies
04-11-2013 06:54 AM
I am looking to attach custom attributes to autocad features (lines, polylines, polygons, points) so that when we insert the dwg into ArcGIS the attrubutes are linked to the feature in both autodesk and gis. I am thinking a dwg seed file will perform this task but am looking for some help understanding and implementing the procedures.
Alfred.NESWADBA
Message 2 of 4 (267 Views)
Re: Creating and using dwg seed file
04-11-2013 10:38 AM in reply to: MWRA
Can be done with "object data" (>>>details<<<).
- alfred -
Alfred NESWADBA
antoniovinci
Message 3 of 4 (263 Views)
04-11-2013 10:50 AM in reply to: MWRA
As far as I know, the DWG format with OD is not fully readable by ARCxxx, i.e. you can transfer the only geometry.
Why don't you simply use the shapefile as normal interchange format between cad and gis..?
Alfred.NESWADBA
Message 4 of 4 (259 Views)
04-11-2013 10:58 AM in reply to: antoniovinci
Thank you, you are fully right, I missed the point that this DWG has to be inserted into an ArcGIS-project. I also was thinking about just data-creation with Map3D and AutoCAD entities and then use MAPEXPORT to get a SHP exported!
Sorry for confusion!
- alfred -
Alfred NESWADBA
You are not logged in.
Ask the Community
