AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Create points from x, y coordinates within attached database
7 REPLIES 7
Message 1 of 8
LeMay1327
1614 Views, 7 Replies
Hi there,
I'm currently working with a drawing that has thousands of polygons.  The drawing is a shapefile that I exported to AutoCAD map 3D via ArcMap 10.1. My issue is that I need to link this drawing to a ms access database that has the attribute data for each of the indvidual polygons.
If I have the x and y coordinates (UTM Easting and Northing) for the center of each polygon in the database (connected to the drawing via an odbc connection), is there anyway that AutoCAD can generate a point layer from these coordinates with the attribute data attached?  Sorry if this question may seem a little strange, but I am very new to AutoCAD and I am desperate to find an answer.
Andrew
7 REPLIES 7
Message 2 of 8
antoniovinci
in reply to: LeMay1327
This "spatial join" is quite possible only if the X,Y coordinates are stored in the Access records.
Message 3 of 8
Murph_Map
You need to either convert the polygons to SDF or shp and data connect to that then do a join to the odbc connection  or just data connect to the shape file from ArcGIS.
Murph
Supporting the troops daily.
Message 4 of 8
LeMay1327
in reply to: Murph_Map
Thanks for the reply.
I do have the the x,y coordinates of the points in a "Locations" table within my database.  The main reason I need to perform this link is that all the labelling information for the polygons is within the database (it's a cemetery so the polygons are individual plots, and the labelling info is a unique plotID). The goal is to be able to change/update the labelling of the drawing by altering records with database forms.  I know it would be easy to complete this task is ArcMap (which is the program I work with most often), but I am doing it in AutoCAD 3D because I no longer have access to an ESRI software license.
If i convert the drawing back to a shapefile (or sdf), and conduct this "join" will i be able to successfully label the drawing with the info from the database?
Thanks again,
Andrew
Message 5 of 8
Alfred.NESWADBA
If you just need to show labels you don't need to join the polygonal and point datasets, you can use the labeling directly from your point-source.
If you connected to your point data (using command _MAPCONNECT right-click on the GIS-layer for the points (within the MAPWSPACE-dialog and set it's style to show the labels from the data you have available in the point source.
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
Message 6 of 8
Good point, Alfred, I agree totally.
Message 7 of 8
LeMay1327
in reply to: Alfred.NESWADBA
Thank you very much,
This worked well..
One more question, If i was to have the xy data stored in another database (say mySQL or PostGRE) would it be possible to do the same thing?
Cheers,
Message 8 of 8
Alfred.NESWADBA
As long as you find a provider in the list of supported GIS-data source types (in the dialog doe _MAPCONNECT) you can do.
If you don't find a provider you have the chance to go to www.osgeo.org and search for a data-provider supporting your format, if you find one you can add this "technologie" so you get access to it via _MAPCONNECT.
- alfred -
Alfred NESWADBA
”Boost
