AutoCAD Map 3D General
Active Member
stephane.aubertin
Message 1 of 3 (889 Views)
Create Legend in Tools of the Display Manager tab in Map 3D 2014
889 Views, 2 Replies
12-12-2013 10:32 AM
I'm in AutoCAD Map 3D 2014.
In Tutorial : Creating a Map Book With an Inset / Lesson 3: Create A Map Book / Exercise 1: Create a key map view and a legend /
4.Generate a legend that you can link to the Legend viewport.
    Switch the Task Pane to the Display Manager tab.
    Click Tools --> Create Legend....
I do not have to create a legend in the tool list.
To be able to create a legend , I must be in paper space and choose a viewport ( omething I 've seen on the web for earlier versions).
The same problem occurs in Tutorial: Building a Map / Lesson 6 : Creating a Legend
I use the tutorial provided in the Help Map 3D 2014 , not the WEB . I have a French tryout version of to MAP 3D 2014, but in an English version , I saw the same problem.
This is a sceen captur of the Display Manager tab Tools
Is this an error in the tutorial ?
Should I do something else, for the Create Legend to be in the tools menu ?
Is impossiblen create a legend in the model space ?
Thank you
Stephane A. Aubertin
Responsable - traitement de l'information (gestion des espaces)
Service de la planification et des projets immobiliers
HEC Montréal
www.hec.ca
Murph
Message 2 of 3 (871 Views)
Re: Create Legend in Tools of the Display Manager tab in Map 3D 2014
12-12-2013 03:21 PM in reply to: stephane.aubertin
In lesson 6 of exerice 1 of creating the legend look at step 8. You need to switch to the layout (paper space) to insert/create a legend. The tutorial is right just not written or explained as well as it could be.
Murph
Supportting the troops daily.
Active Member
stephane.aubertin
Message 3 of 3 (856 Views)
12-13-2013 12:09 PM in reply to: Murph
I think they forgot this explanation in the French translation. I just watch the Video, and they actually go in paper space.
thank you
HEC Montréal
www.hec.ca
You are not logged in.
Ask the Community
