AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Copy not working
2 REPLIES 2
mekohler
322 Views, 2 Replies
Copy not working
When I use the copy tool, not copy and paste, the object that I copy doesn't show up.  I click on an object click the copy took then click in the location where I want the new object, nothing shows up.  Then if I save the drawing, close and reopen it, the object will be show up in the new location.  This is getting frustrating.  It sometimes happens with move and rotate.  I'm using 2013 64 bit version on Windows 7.
Michael Kohler
2 REPLIES 2
antoniovinci
in reply to: mekohler
Never heard about it, herr Kohler: check if _REGENAUTO is set to ON...
Alfred.NESWADBA
What type of object is it? Does that happen with every (also new) drawing(s) with just a line as object?
Do you have some objects in front and maybe the copied one is in the background of drawing-order after defining the new position?
One try is to disable to hardware-acceleration to be more safe for some incompatibilities of your display driver (command _3DCONFIG ==> manual tune)
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
”Boost
