AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Copy,Paste,Erase problem,...
2 REPLIES 2
SepantaMehr
498 Views, 2 Replies
When i need erase or copy and paste 10.000 objects it take me more than 1 min,...
I tried to diferent version of CADmap3d (Autocad Map 3d 2013,2012,2011,2010), but cant help me,...
CPU: intel core i7 3.4 GHz
RAM: 8GB
VGA: Nvidia 1 GB
windows 7 Ultimate x64
pleas help me
2 REPLIES 2
What object-types are these objects? Simple AutoCAD-geometry like lines, or more complex objects like polylines/blocks or very complex objects like XRef's or proxy-objects .... or are these objects from any referneced GIS-dataset like SHP, SDF, ...
How big is this drawing?
Have you tried to first cleanup your drawing using _PURGE?
Have you verified the number of defined scales in your drawing (command _SCALELISTEDIT)
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
cjneper
in reply to: SepantaMehr
Unfortunately this is a known issue with 64 bit Acad, and has been a problem for several releases now.  For some reason 64 bit Acad cannot erase large datasets.  It works fine in 32 bit Acad.  I can imagine the incredulous look on your face right now....  Hard to believe this has not been fixed after several releases, erase is such a basic function.
”Boost
