AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Coordinate System Library not showing all of the Coordinate Systems
3 REPLIES 3
mikebaldi
592 Views, 3 Replies
I am using Civil 3D 2012 with SP1. When I use data connect and attempt to edit the coordinate system the Coordinate System Library that pops up only shows 5 No Datum coordinate systems. The Datum box under Show is uncheck, unfortunately it is also greyed out and uncheckable.
How do I get this box checked?
Thanks.
3 REPLIES 3
in reply to: mikebaldi
Not sure but problem seems to me is Map 3D installation
mikebaldi
are your boxes greyed out?
NateMoore
I'd first try running the program as Administrator and see if you then get access. If you do, turn off UAC and try again.
Nate Moore, GISP
Geospatial Premium Support Specialist
Global Services
Autodesk, Sarl
”Boost
