AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Convertpstyles
2 REPLIES 2
461 Views, 2 Replies
Convertpstyles
What can I do if I have AutoCAD map 2002 installed and the CONVERTPSTYLES command does'nt work? I've tried to re-installed migration assistance but it does'nt work at all.
Thank!
Sylvain
2 REPLIES 2
Error when using CONVERTCTB or CONVERTPSTYLES: Unknown command
http://support.autodesk.com/getdoc.asp?id=TS47423
Please, DO NOT send technical requests to me via private e-mail
Tracy Lincoln
Assistant Moderator, Autodesk Discussion Groups
Discussion Group Links:
Index: http://discussion.autodesk.com
Rules: http://discussion.autodesk.com/webx?groundrules
Product Support: http://support.autodesk.com/
Knowledge Base: http://support.autodesk.com/ViewAnswerworks.asp
Downloads: http://support.autodesk.com/Downloads.asp
sorry, I've tried that but the command still not working, I'm unable to load the "acadcvps.arx" file...
Is the command convertpstyles supopse to work on AutoCAD MAP 2002?
Thank!
Sylvain T.
”Boost
