Hello
MAPIMPORTMAPGUIDE is working right with MAP 2008-2010, so maybe something is wrong on your PC !
Did you create the OD (Object Data) MAP table ?
Did you map the 3 SDF v2 possible attributes (Key, Name, Url) to your OD table ?
Bye, Pat
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
