AutoCAD Map 3D General
Member
Neman_
Message 1 of 12 (1,318 Views)
Contour Lines
1318 Views, 11 Replies
03-21-2013 01:19 AM
Hello there!
I need a little help from you. I want to make contour lines in autocad 2010 map 3d, but dont know how to start and where :smileyvery-happy:.
I have xyz coordinates in. txt format , something like this:
http://imageshack.us/photo/my-images/259/58611400.jpg/
I tryed to do with spline, but its pretty hard some times :/. I need something that i can import and let autocad draw the contours, if its possbile (import txt or another format if its possible) !??
Thanks for any help, and sorry if i dont have such a good english spelling :smileytongue:
Distinguished Contributor
bingeomatics
Message 2 of 12 (1,281 Views)
Re: Contour Lines
03-22-2013 01:41 AM in reply to: Neman_
Hello. If you have AutoCAD Civil, it is very universal software to do this operation in it. If you have only AutoCAD Map, you can only import this point list as Esri Shape file (point geometry) and creat DEM file from GIS file and only after it you can take contours from that DEm file.
Binnat Khalilov
*Expert Elite*
antoniovinci
Message 3 of 12 (1,276 Views)
Re: Contour Lines
03-22-2013 02:32 AM in reply to: bingeomatics
You don't need that conversion: simply use the _MAPIMPORT command to load the .CSV text file, sir.
bingeomatics
Message 4 of 12 (1,269 Views)
Re: Contour Lines
03-22-2013 05:06 AM in reply to: antoniovinci
antoniovinci, I know it, too. But he want to creat relief contours.... How he can creat contours by those points or blocks?
Binnat Khalilov
*Expert Elite*
antoniovinci
Message 5 of 12 (1,267 Views)
Re: Contour Lines
03-22-2013 05:34 AM in reply to: bingeomatics
Binnat, you wrote: "you can only import this point list as Esri Shape file"...
So I replied that it's not necessary, while the contour generation is another thing.
I agree with you he may create a DEM from those points, but here's an alternative:
  1. http://www.cadstudio.cz/en/apps/dtm/
Once you have the DTM as 3Dfaces' bunch, you can generate the contours with this jewel.
bingeomatics
Message 6 of 12 (1,263 Views)
Re: Contour Lines
03-22-2013 05:48 AM in reply to: antoniovinci
Hmm? I understant you, antoniovinci.
I said it for only contours.
But, I didn't knew about "CADstudio DTM". It is very good modul for AutoCAD users- who have not AutoCAD Civil.
Thanks.
Binnat Khalilov
Active Contributor
rreid
Message 7 of 12 (1,256 Views)
Re: Contour Lines
03-22-2013 07:29 AM in reply to: Neman_
Neman_
You can create a surface easily in Map 3D 2013.
Simply go to the CREATE tab on the ribbon and select "Create from Points" on the 3D Surface Panel.
This will create a RASTER surface.
If you wish to add contours to your surface, then simply select the raster surface and the Contextual Ribbon for the Raster Layer will appear. There you will see the "Create Layer" function on the CREATE panel.
Hope this helps!
Richard W. Reid, Jr. PLS
AutoCAD - Civil 3D - Map 3D - ESRI - Google
AutoCAD Civil 3D Implementation Expert
*Expert Elite*
antoniovinci
Message 8 of 12 (1,243 Views)
Re: Contour Lines
03-22-2013 11:56 AM in reply to: rreid
It doesn't matter, 'cause the OP owns Map2010, unless he can prove that it works for him...
Active Contributor
rreid
Message 9 of 12 (1,240 Views)
Re: Contour Lines
03-22-2013 12:01 PM in reply to: antoniovinci
This function was available back to MAP 3D 2011, I don't have 2010 to test. Thank you, Richard W. Reid, Jr. PLS Senior Consultant - CIVIL AutoCAD Civil 3D Implementation Expert Autodesk Certified Professional MICRODESK, INC. 800-336-3375 (Main) 781-419-8115 (Direct) www.microdesk.comFacebook | Twitter | Blog| Microdesk CaresThe trusted advisor for the AECO industry AUTODESK 2012 NORTH AMERICAN PARTNER OF THE YEAR
*Expert Elite*
Murph
Message 10 of 12 (1,234 Views)
Re: Contour Lines
03-22-2013 05:19 PM in reply to: rreid
It's there in 2010 as well.
Murph
Supportting the troops daily.
You are not logged in.
Announcements
Need installation help?
Ask the Community
