AutoCAD Map 3D General
Active Member
Message 1 of 8 (584 Views)
Connection AutoCAD Map 2014 to ArcSDE 10.1
584 Views, 7 Replies
09-02-2013 02:27 PM
Hi everyone,
I am trying to connect ArcSDE 10.1 to AutoCAD Map 2014. Does anyone know which is the process most suitable to solve this connection with FDO provider?.
In the attached document, you can see that the connection is made, but didn't find any DataStore, that I have to do to see such data Store.
Valued Contributor
Message 2 of 8 (554 Views)
Re: Connection AutoCAD Map 2014 to ArcSDE 10.1
09-03-2013 09:24 AM in reply to: SS026080
I've not done this with Oracle, but have made it work with SQL Server and I have to manually populate the Data Store name before I am able to connect.
I hope it goes better for you than it has for me because our connection is terribly slow and unstable.
Active Member
Message 3 of 8 (545 Views)
09-03-2013 10:32 AM in reply to: Gary_Braun
Thanks Gary,
In Oracle Spatial and SQL connections work perfectly...
The problem is with ArcSDE10.1, we want to see this data in AutoCAD Map
Valued Contributor
Message 4 of 8 (541 Views)
09-03-2013 10:34 AM in reply to: SS026080
Your response is a bit unclear to me. You do realize that I reply was referring to Map 3D so you could bring in and work with data there, right?
Active Member
Message 5 of 8 (531 Views)
09-03-2013 12:54 PM in reply to: Gary_Braun
Thanks Gary,
I am working with AutoCAD Map 3D 2014 and I need to  use   the FDO provider for ArcSde.
You know what are there quirements and how to proceed to connect this data?
Santiago
Valued Contributor
Message 6 of 8 (526 Views)
09-03-2013 01:04 PM in reply to: SS026080
Santiago,
I as I said, I don't use Oracle so I can't promise this will work, but here are a couple of things to try based on the screen shots you attached.
1. Instance Name: When connecting to SQL Server based SDE data the server name needs to be included in the string and I'm making an assumption that Oracle might need it as well, which In your case it would make the string = "sde:smileysurprised:racle11g:rsgis2"
2. On the second page of your attachement you show the empty dropdown box for Data Store. Try typing the name of your Oracle database in there and see if it lets you connect afterward.
good luck
Valued Contributor
Message 7 of 8 (525 Views)
09-03-2013 01:07 PM in reply to: Gary_Braun
Not sure how that colon got turned into a smiley face, but it is supposed to be a colon.
braudpat
Message 8 of 8 (480 Views)
09-06-2013 02:31 AM in reply to: Gary_Braun
Hello
Just a "stupid" question ...
Have you installed the "required" ESRI DLLs into the bin/fdo (MAP > 2011) OR fdo/bin (MAP < 2012) folder ?
Are you using 32 bits ou 64 bits MAP ?
Bye, Pat
Bye, Pat
You are not logged in.
Ask the Community
