I'm pretty new to AutoCAD and very familiar with GIS. We maintain most of our GIS data in either personal (.mdb) or file (.gdb) geodatabases. I have AutoCAD Map 3D 2012 and want to be able to connect to these geodatabases. Where can I find the FDO provider to connect to these types of geodatabases and what is the process for updating the providers list for AutoCAD?
Thanks in advance!!
I remember that I read anywhere about a GDB-Provider for Map3D2012, but I didn't find that doc plus I have no data and so I've no chance to try it. Sorry.
Most info about FDO-providers you'll find at www.osgeo.org ==> there you find all available providers and also the description of how to add provider-files and configure them.
Good luck, - alfred -
This old blog post is still extremely relevant.
http://map3d.wordpress.com/2006/12/05/map-3d-2007-and-connecting-to-a-esri-personal-geodatabase/
The ArcGIS provider will allow connections to personal and file geodatabases (on 32-bit systems). You'll need an ESRI license available in order to use that provider, which is in the box in the 2012 release.
Hi Nate,
>> The ArcGIS provider [...]
And where is this ArcGIS-provider? When I start Map3D2012 (or Civil3D2012) I only see an ArcSDE-provider ... and I don't think you can use that to get connected to a GDB. I searched also for it as I read that in some NewFeaturePapers for Map3D2012, but didn't find it.
...oops ... or is it only visible in the 32bit version of Map3D?
- alfred -
Yes, it's off in the x64 versions (to avoid that same frustration).
I downloaded the 64bit OGR provider from OSGEO (since I have a 64bit machine) and added it to the 'fdo' folder inside the 'bin' folder for both Map3D 2012 and Civil3D 2012. I then added the OGR provider to the 'providers' xml document...are there any other steps I need to take?
Thanks for all the help, I really appreciate it!
That should be all that you need to do. However (and I haven't been able to find OGR docs that confirm this) it seems that the provider is 32 bit only - likely it's the same ODBC drivers that are leveraged for the GDB as for Access MDB and it's not x64 ready. Sort of like here: http://gisexchange.typepad.com/blog/2010/08/odbc-on-x64-operating-systems.html
When I try to connect to a personal geodatabase (.mdb) or file geodatabase (.gdb) I get the following error messages. Do I need a driver for the personal geodatabase connection...? If so, where can I get it? Or, do I need the 32-bit ORGProvider.dll from OsGeo?
Is there some other provider other than OGR to connect to a file geodatabase?
Thanks for the help!
Failed to connect.
Failed to open FDO connection.
Connect failed: Unable to initialize ODBC connection to DSN for DRIVER=Microsoft Access Driver (*.mdb);DBQ=\\Whe-cadd\whe_office\PROJECTS\11249100 ELMHURST\5.0 GIS\Output\Temporary Geodatabases\Temporary.mdb, [Microsoft][ODBC Driver Manager] Data source name not found and no default driver specified
When I try to connect to a file geodatabase (.gdb) I get the following error message:
Failed to connect.
Connect failed:
If your computer is 64 bit, and you are using Map 3D 2012, then use the 3.6 FDO OGR for 64 bit, downloadable from here
http://fdo.osgeo.org/content/fdo-360-downloads#3.6.0_win64_provider_binaries
That is the link where I got the OGR Provider 3.6 for 64bit...and I'm receiving the previous error using that provider.
Here is a rundown of my versions for everything...
1) Windows 7 64bit
2) AutoCAD Map3D 2012 and Civil3D 2012
3) ArcGIS 10
4) MS Office 2007 (32bit since Office 2007 only comes in 32bit)
Am I not able to connect to a personal geodatabase (MS Access based - .mdb) because I have Office 2007 which is 32bit and I'm running a 64bit machine?
I'm also unable to connect to a file geodatabase. I've tried both OGR and ODBC providers without any luck.
Is it as easy as downloading and then running the install? Is there any type of configuring that needs to be done afterwards?
So the steps I'd need to take are....
1) Uninstall MS Office 2007
2) Install 2010 Database Engine
3) Re-install MS Office 2007
Is that correct?...the reason I ask is because if I try to install this on top of MS Office 2007 I get an error message saying I need to uninstall.
This was my 3rd year of missing after 12 years of going. Beginning not to miss it.
