When trying to connect MySQL 5.5 to AutoCAD Map 3D in W7 x64, a file called "libmysql.dll" is required. In the Help Package of the program, it is said that this file must be installed before you can make the connection.
The problem is that it isn's specified where and how must this file be installed. Someone got to know?
I've found this file in the MySQL 5.5 directory. I've tried to put it in the FDO folder or AutoCad Map 3D, I've tried to put it inside system32 and syswow64 folders. I've tried to register this dll using regsvr32 in command prompt putting it inside those folders... and I get always errors. I don't know what else can I do to get this file installed so I can connect to MySQL throug AutoCAD Map 3D.
Please, Help!!!!
in Map help (2013) is written:
If you cannot connect to your MySQL data source, you may see an error message: "Specified credentials are not valid or the provider is unable to establish a connection." To resolve the issue, copy the libmySQL.dll file into the AutoCAD Map 3D\FDO\bin folder and try again.
Tried that?
Good luck, Rob
I'm not familiar with MySQL but I believe you need the 64bit version of the dll in question as Map is a 64bit app. You mentioned that you found the dll in MySQL installation folder - is that a 32 or 64bit installation?
Just guessing,
Rob
