AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Compatible 64-bit
4 REPLIES 4
239 Views, 4 Replies
Compatible 64-bit
Can anybody tell me if Autodesk Map 3D version 2006 can be installed on a 64-bit computer?
It does not have to work 64-bit, for example, it would be enough if it can be installed as a 32-birt version, but on a 64-bit computer.
4 REPLIES 4
I pretty much doubt it can be installed seeing how version 2008 can not be
installed on a 64 bit system.
Murph
wrote in message news:5862276@discussion.autodesk.com...
64-bit computer?
Matt.Anderson
Install it on a Virtural XP 32-bit machine inside your 64bit machine.
Matthew Anderson, PE CFM
Product Manager
Autodesk (Innovyze)
YES ! I asked autocad the same question and they got me installed on WinXP64bit. It works great! Tom
How did you get it installed? All I get is an error stating that this is a 32-bit application.
”Boost
