I had a problem this morning where for some reason I needed to do a drawing recovery on a map - which is fine, all seems well.
The problem is that now when I type a command, it doesn't appear next to the cursor anymore. It's not really a NEED having it there, but I've gotten to like that in the newer CAD versions, and now I can't find the setting that makes it come back. Sure I CAN type everything and have it show just at the bottom of the screen, but I'd rather have my dynamic field back.
Anyone know how I can restore it?
Solved by Alfred.NESWADBA. Go to Solution.
you can switch the dynamic mode by:
- alfred -
Thank you very much. I had a feeling it was one of those simple solutions I just couldn't locate...
I have the same problem, i cant find the dimentions of any thing, but i also cant click on more than one thing. I dont know if its different on a mac. I tryed but it did nothing.
You are the bomb!!! This crap was driving me crazy... I spent a better of a hour and half trying to fix it. You never realize how dependent you get on something some thing a simple as that. So, many thanks to you...
open this helpful hint.
dave
>> at your 3rd bulletin point you said
These 3 items are all alternatives, each of them does the same, turning dynamic input on or off
>> when I type a command it still shows in the bottom left corner
If DYNMODE set to 3 does not show the keys types in near the cursor then verify that DYNPROMPT is set to 1.
- alfred -
Thank you,
That solved my issue as well. Gotta love the unknown updates that switch settings you never knew about....lol
Thanks!
Is there anyway I can lock this feature so it doesn't change back?
It should not change.
If it changes on your side then use the SYSVARMONITOR (>>>details<<<) so you get informed when it changes, and so knowing then which function or which tool does that.
- alfred -
Thanks, that is what I needed. the DYNPROMPT command turned it on and off for me.
It was so helpful thank you. I was getting so frustrated and my professor was not able to understand what i was trying to say!!
