style="BORDER-LEFT: #000000 2px solid; MARGIN-LEFT: 5px; MARGIN-RIGHT: 0px; PADDING-LEFT: 5px; PADDING-RIGHT: 0px">
"dc johnson" <I
href="mailto:DJOHNSON@WWCENGINEERING.COM">DJOHNSON@WWCENGINEERING.COM>
wrote in message
href="news:3B701F48.858D1185@WWCENGINEERING.COM">news:3B701F48.858D1185@WWCENGINEERING.COM...
believe that the only place that has the tolerance correction is under
the
drawing cleanup routine. But you need to be carefull when
increasing the
tolerance or you might end up deleting a short segment that
you actually want or
creating a small polygon that you cant see but may
affect the total area (we
deal with several square miles of data at one
time).
Dave
@Anonymous wrote:
> Thanks DC, I did figure
out the process of creating a topology but was not
> resourceful enough
to use Drawing Cleanup to intersect all of the linework.
> I spent
a while using a one-point break (call me a chucklehead). I
> appreciate
the time you put into your response. I just want to confirm one
> thing.
If the linework is drafted poorly, is the Drawing Cleanup routine the
only way to correct lines & arcs that don't intersect or align? Is there
any
> tolerance for correction in the topology commands?
Thanks again,
> John
