I am currently working on my first GIS project. The survey crew has collected Storm / San Manholes, Water Valves and Fire Hydrants with a VRS GPS. Each of these features have unique identifiers. The scope of the project is to produce a base drawing that has all of these feature located with the GPS and have either static or dynamic data attached. The water mains and storm / san mains are static. The water valves and fire hydrants are going to be dynamic. The dynamic features all have blocks defined with block attributes setup. Instead of manually editing every block attribute to create the unique identifier. I was trying to create a link between a "Civil Point" and an external database without success. Is there an easy way to have the block attribute read a value from a "Civil Object" (ex description) I tried to use the "insert a field" within the attribute and use object. The only option with LDT is "Object Name". If I try this same procedure in MAP 3D I get more options except for the point information i need. If I list a point or properties for a point it gives me the information I would need for the attribute. Any help or suggestions would be greatly appreciated.
Brendan
Civil 3D 2008
Land Desktop Companion 2008
Map 3D 2008
