I created the Lisp and loaded it in Startup. I can see the script is loading
at startup via the Text window (F2), but the command "ade-userget" does not
work (Command: ade_userget Unknown command "ADE_USERGET". Press F1 for
help.)so I can't verify it according to your directions.
"Murph" wrote in message
news:417d1be2$1_1@newsprd01...
> It's Autolisp, to use it cut and paste from ;autologin to the end
> (autologin) into a new text file. Notepad works well for it, then save the
> file as Autologin.lsp. Place that file in your support path for AutoCAD
> Map.Then in autoCAD from the pulldown Tools>AutoLISP>LOAD, In the dialog
> box
> that pops up,in the bottom right corner is the Startup Suite, click on the
> Contents button. Click "ADD" and browse to the file. OK/close back out
> thru
> all the dialogs. Exit AutoCAD and restart it. To check if it works after
> Map
> opens, type (ade_userget) at the command line. If it works it will print
> to
> the command line "SUPERUSER".
> Murph
