I am importing DOT drawings from Microstation, and as part of this much of the text is assigned a specific color within the text box (ie: you can double-click the text to edit, highlight the text, and change from "Red" to "by layer"). This is extremely tedious to change each and every piece of text to "by layer" so I can better control colors throughout the drawings.
Is there a command similar to "SETBYLAYER" that works for text as well? SETBYLAYER has really helped me with a similar block problem, but I am still manually changing text.
Matt
