AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Can't add data
4 REPLIES 4
neilyj666
1196 Views, 4 Replies
Can't add data
I'm trying to connect to a folder of SHP files.
I select all the shape files and hit add to map (before.jpg) and then the selection tick get removed and add to Map is greyed out and nothing is added to the map (after.jpg)
Any ideas as to what I'm doing wrong??
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
4 REPLIES 4
antoniovinci
in reply to: neilyj666
Try to load those shapes one by one, until you find out the guilty.
Murph_Map
That's normal, did you zoom extends? Check the Display Manger to see if the layers were added there?
Murph
Supporting the troops daily.
neilyj666
Thanks for the suggestions - I rebooted and all seems ok now
I'm having the same problem, but rebooting does not help.  Any suggestions?
”Boost
