AutoCAD Map 3D General Discussion
rwatson654
Message 1 of 4 (225 Views)
C3D to ArchGIS
225 Views, 3 Replies
09-26-2013 11:30 AM
Please excuse my ignorance with this.  We have Civil 3D 2013 (and 14).  We need to create an ArchGIS file that includes pipe networks created with C3D, pavement and building which are polylines.  What is the best method to approach this, export from C3D to shp file, or import dwg into ArchGIS.  Since no one here has worked is familiar with map where would be a good place to start looking for information on accomplishing this task.
C3D 2013 (latest updates), 2014 Infrastructure Design Suite
Win 7 Pro, 64-bit
16 GB RAM
antoniovinci
Message 2 of 4 (222 Views)
Re: C3D to ArchGIS
09-26-2013 11:39 AM in reply to: rwatson654
I fear ARCxxx won't be able to understand the inner georeferency of a .DWG created by Map/Civil...
So try to _MAPEXPORT all to a multiclass shapefile, sir.
Alfred.NESWADBA
Message 3 of 4 (210 Views)
Re: C3D to ArchGIS
09-26-2013 01:14 PM in reply to: rwatson654
You can use command _AECCEXPORTTOSDF to export Civil specific data (like alignments, parcels, ...) to SDF and then use bulk copy to convert SDF to SHP.
To export plain AutoCAD geometry (like lines, arcs, polylines, ...) you will first have to use the cleanup- and topology tools (built in Map3D and also in Civil3D) to create GIS objects (with other words make CAD-objects to clean GIS-objects). When that is done you can export the topology using _MAPEXPORT to create SHP-files from that.
Good luck, - alfred -
Alfred NESWADBA
rwatson654
Message 4 of 4 (190 Views)
Re: C3D to ArchGIS
09-27-2013 05:40 AM in reply to: rwatson654
Thanks for the response.  The adivce has helped.
You are not logged in.
Ask the Community
