AutoCAD Map 3D General
Active Contributor
Message 1 of 7 (385 Views)
Best way to reference a Sid raster image and have it clippable?
385 Views, 6 Replies
04-05-2013 02:19 PM
I'm still learning some of the basics in the AutoCAD Map features.  Most of my work has been using a map that is connected to data.  My raster image is connected to a Sid file which covers more area than I usually need to work with.
What is the best way to work with a small area at a time? I cannot seem to imageclip the connected raster image.
Thanks for help for probably a pretty basic question.
Murph
Message 2 of 7 (373 Views)
Re: Best way to reference a Sid raster image and have it clippable?
04-05-2013 03:28 PM in reply to: Jfactory
With data connection to a raster file you can zoom in to the area then right click on the raster layer in the display manager and do a refesh. Now you can zoom out if you need to and it somewhat acts like a clipped image. Just watch the regens or redraw commands.
Murph
Supportting the troops daily.
Distinguished Contributor
bingeomatics
Message 3 of 7 (364 Views)
04-06-2013 01:48 AM in reply to: Murph
In my AutoCAD Map that function is called "Resample Raster".
Binnat Khalilov
Murph
Message 4 of 7 (361 Views)
04-06-2013 03:41 AM in reply to: bingeomatics
Correct, I had a brain freeze and didn't verify as I replied.
Murph
Active Contributor
Message 5 of 7 (347 Views)
04-06-2013 03:13 PM in reply to: Murph
Thank you for the replies. I'll have to try this out when I'm at work on Monday :smileyhappy:
Valued Mentor
Message 6 of 7 (340 Views)
04-07-2013 02:59 AM in reply to: Jfactory
Depending on the image file size and your computer capability try _mapiinsert, zoom extents, zoom window to the area you need, and _view to view manager and NEW named view.  You can then select the view by the name in the list ad quickly get to the area of the image you want to see.  this avoids the resample raster routine also.
dave
braudpat
Message 7 of 7 (335 Views)
04-07-2013 05:56 AM in reply to: parkr4st
Hello
If you are using FDO sources (Rasters, SHP, SDF, SQLite, etc), you can use the MAPUPDATEMAP command
to update ALL FDO connections ... It's very useful !
Bye, Pat
Bye, Pat
You are not logged in.
Ask the Community
