AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Automatically Create Annotation?
2 REPLIES 2
DaveMartin4189
315 Views, 2 Replies
I'm creating/applying Object Data for Pipe Size and Valve Number for a Water Main Atlas I'm creating in Map 3D.
Is there a way to define Annotation for the Valve Nubmer and Pipe Size, so the Annotation is automatically created when each Valve feature (entity) is created?  Or when each Pipe entity gets drawn?
I'd appreciate any suggestion on how to automate this process.
Thanks much,
Dave Martin
Hancock Engineering Co.
dmmartin@ehancock.com
708-865-0300
2 REPLIES 2
Murph_Map
in reply to: DaveMartin4189
You can use map annonation blocks. It's not going to label them as you create the entites but allows you to insert the block after you create the features.
Murph
Supporting the troops daily.
braudpat
in reply to: Murph_Map
Hello
Look at this subject : (You could find interesting Infos)
http://forums.autodesk.com/t5/AutoCAD-Map-3D/Way-to-locate-Annotation-where-feature-s-selected/td-p/...
Bye, Pat
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
”Boost
