We got one step further but then it stopped again: what does one have to
do to create a spatial index?
After creating user/scheme I logged on to oracle from Map
After exporting some testdata, Map had created serveral tables
automatically:
ADMPALIASDEFINITION,
ADMPDRAWINGNAMES,
ADMPENTITIES,
ADMPLAYERDEFINITION,
ADMPLINKTEMPLATES,
ADMPODDEFINITIONS,
ADMPODTANSITABELL,
ADMPQUERIES,
But neither "index spatial files" or "import data" worked. We get error
messages when trying to compute extents: "unable to update metadata
table -table doesn't exist" We assume (no helptopic) that one has to
create its own spatial index file.
So we created manually a table called
SDO_GEOM_METADATA
but it didn't work either. Map was still not able to performe indexing
on the spatial data.
We guess that it might have to do something with different versions of
Oracle: we got the tablename from 8.1.5 but MAP required the 8.1.6
client
Am I right? Does somebody have the correct table-, columnnames for
spatial index table ?
/Hans-Jørg
"Crispin @ IME-GIS.co.uk" wrote:
> see thread from 20/7/01 > Should I make some additional configuration
> first?
> Warren almost got it - you need the Oracle client (installed and
> configured)
> but this error comes from a lack of the "OO4O" component ("Oracle
> OLEDB for
> Objects" I think).
> This is also freely downloadable from Oracle - I read it is needed
> somewhere
> but now can't find the reference. The Map help should certainly make
> it
> clearer.
> Crispin
> www.IME-GIS.co.uk
> "infotech" wrote in message
> news:f071640.-1@WebX.maYIadrTaRb...What is the procedure to
> connect to Oracle spatial from MAP 5.0?
> When we invoke the "ORACONNECT" button we got the following
> error. Please respond to our error message.
> AcMapOrclUI.arx cannot find a procedure that it needs.
> ; error: ARXLOAD failed
