AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Autodesk Map 5.0 and Oracle Spatial
5 REPLIES 5
333 Views, 5 Replies
What is the procedure to connect to Oracle spatial from MAP 5.0?
When we invoke the "ORACONNECT" button we got the following
error. Please respond to our error message.
AcMapOrclUI.arx cannot find a procedure that it needs.
; error: ARXLOAD failed
5 REPLIES 5
see thread from 20/7/01
> Should I make some additional configuration
first?
Warren almost got it - you need the Oracle client (installed and
configured)
but this error comes from a lack of the "OO4O" component ("Oracle
OLEDB for
Objects"  I think).
This is also freely downloadable
from Oracle - I read it is needed somewhere
but now can't find the
reference.  The Map help should certainly make
it
clearer.
   Crispin
href="http://www.IME-GIS.co.uk">www.IME-GIS.co.uk
style="BORDER-LEFT: #000000 2px solid; MARGIN-LEFT: 5px; MARGIN-RIGHT: 0px; PADDING-LEFT: 5px; PADDING-RIGHT: 0px">
What
When we invoke
error message.
; error: ARXLOAD
failed
We got one step further but then it stopped again: what does one have to
do to create a spatial index?
After creating user/scheme I logged on to oracle from Map
After exporting some testdata, Map had created serveral tables
automatically:
ADMPALIASDEFINITION,
ADMPDRAWINGNAMES,
ADMPENTITIES,
ADMPLAYERDEFINITION,
ADMPLINKTEMPLATES,
ADMPODDEFINITIONS,
ADMPODTANSITABELL,
ADMPQUERIES,
But neither "index spatial files" or "import data" worked. We get error
messages when trying to compute extents: "unable to update metadata
table -table doesn't exist" We assume (no helptopic) that one has to
create its own spatial index file.
So we created manually a table called
SDO_GEOM_METADATA
but it didn't work either. Map was still not able to performe indexing
on the spatial data.
We guess that it might have to do something with different versions of
Oracle: we got the tablename from 8.1.5 but MAP required the 8.1.6
client
Am I right? Does somebody have the correct table-, columnnames for
spatial index table ?
/Hans-Jørg
"Crispin @ IME-GIS.co.uk" wrote:
> see thread from 20/7/01 > Should I make some additional configuration
> first?
> configured)
> OLEDB for
> Objects" I think).
> This is also freely downloadable from Oracle - I read it is needed
> somewhere
> but now can't find the reference. The Map help should certainly make
> it
> clearer.
> Crispin
> www.IME-GIS.co.uk
> "infotech" wrote in message
> news:f071640.-1@WebX.maYIadrTaRb...What is the procedure to
Map created index all OK for us (admittedly logging onto a system account on
test server) on an 8.1.6 DB. Two additional SDO tables were created (see
below).
Crispin
SQL> select * from all_tables where table_name like 'SDO%';
OWNER TABLE_NAME
TABLESPACE_NAME CLUSTER_NAME
BUFFER_ ROW_MOVE GLO USE DURATION SKIP_COR MON
MDSYS SDO_GEOM_METADATA_TABLE SYSTEM
DEFAULT DISABLED NO NO DISABLED NO
MDSYS SDO_INDEX_METADATA_TABLE SYSTEM
"Hans-Jörg Schneidt" wrote in message
news:3B72A767.E06F4242@vianova.no...
> automatically:
> ADMPDRAWINGNAMES,
> ADMPENTITIES,
> ADMPLINKTEMPLATES,
> ADMPODDEFINITIONS,
> ADMPODTANSITABELL,
> ADMPQUERIES,
> SDO_GEOM_METADATA
> client
> /Hans-Jørg
> > first?
> > configured)
> > OLEDB for
> > Objects" I think).
> > somewhere
> > it
> > clearer.
> > Crispin
> > www.IME-GIS.co.uk
DWalsh
Hans,
The Map command you need is ORAINDEX. You can also use the Oracle Spatial Index Advisor to generate an index.
Are you using 8.1.5? That might be the problem. We have only tested gainst 8.1.6.
Cheers,
David Walsh
Problem solved. I used a 8.1.6 client towards an 8.1.5 server -that
doesn't work
We installed 8.1.6 server and it works without problems.
Thanks!
DWalsh wrote:
> Hans,
> gainst 8.1.6.
> Cheers,
> David Walsh
”Boost
