AutoCAD Map 3D General Discussion
Active Member
korinagomez
Message 1 of 16 (291 Views)
Autocad Map 3d annotation
291 Views, 15 Replies
04-24-2012 10:40 PM
I have a set of data in excel. how can i annotate my map with this data, such that the map recognizes the name for example of a point and then directs this data to this point.
For example given points A and B in the map. then i have for example 3 columns of data in excel for points A and B.
Thank you.
antoniovinci
Message 2 of 16 (289 Views)
Re: Autocad Map 3d annotation
04-25-2012 01:18 AM in reply to: korinagomez
First you load the .XLS file with _MAPATTACHDB then you link the number of Autocad point to the same field in Excel, by means of the _MAPDEFINELT command.
Active Member
korinagomez
Message 3 of 16 (272 Views)
04-25-2012 05:31 PM in reply to: korinagomez
thank you for replying. when i did what you said, (mapdefinelt), there appears a define link template dialog box, i clicked some of the options for the key selection, but the values do not appear in the map..
sorry, i am really new to this.
antoniovinci
Message 4 of 16 (262 Views)
04-25-2012 10:50 PM in reply to: korinagomez
After the _MAPATTACHDB command and loading your .XLS file, right click on the connection, then choose Properties:
Now you should setup the ODBC driver like this: when everything is ok, you can issue _MAPDEFINELT (I recommend you to learn these powerful commands in the F1 help)...
Active Member
korinagomez
Message 5 of 16 (246 Views)
04-26-2012 06:22 PM in reply to: antoniovinci
wow. thank you for replying..
a table same as my excel file appears,
here is a link of the task i was assigned. am i on the right track or is this possible with autocad map 3d. i was thinking of  making the excel my data source, and an everyday change in values will be visible through changes in the color in my map.. just like a weather map.
http://earthobservatory.nasa.gov/GlobalMaps/view.php?d1=MYD28M
i really appreciate your help. i've been working on this for three weeks now. again thank you :smileyhappy:
Active Member
korinagomez
Message 6 of 16 (239 Views)
04-26-2012 08:14 PM in reply to: antoniovinci
or based on the data, how will i annotate the map with color, such that when assigned a value, it will automatically change color.. as for the link i attached, i will be animating the drawings so as to appear like that.. but coloring now is my only problem.
antoniovinci
Message 7 of 16 (233 Views)
04-26-2012 11:00 PM in reply to: korinagomez
I'm afraid you can't get that.
Software GIS like Map involves links to external databases as text attributes, not as dynamic source to stylize your map in realtime.
By the way, in your spreadsheet I don't see the values A-21, A-22, C-21: how did you join Autocad objects with Excel records..?
Active Member
korinagomez
Message 8 of 16 (230 Views)
04-26-2012 11:33 PM in reply to: antoniovinci
do you mean linking the object to the excel data?? watch this video,after doing this, double click the object, properties ribbon will appear, scroll it down, then you'll see your excel data there..
http://www.youtube.com/watch?v=7D_Y2-89ySA
:smileyhappy:
antoniovinci
Message 9 of 16 (226 Views)
04-27-2012 12:23 AM in reply to: korinagomez
Dear Korina,
I link Autocad stuff to databases since '90 of the past century, so my question was about how YOU did that...
Active Member
korinagomez
Message 10 of 16 (225 Views)
04-27-2012 12:24 AM in reply to: antoniovinci
with regards to my question, i saw a video that is a probable solution, however whenever we click style editor from the analyze tab, it says "to edit style, you need to have a map layer".
does it need to be GIS, or map imported from sql or arcsde?? the map we have was previously made in corel draw and converted to dwg.. sorry for troubling you.
here's the link by the way http://www.youtube.com/watch?v=6ITZnrGfec0
You are not logged in.
Ask the Community
