I have a set of data in excel. how can i annotate my map with this data, such that the map recognizes the name for example of a point and then directs this data to this point.
For example given points A and B in the map. then i have for example 3 columns of data in excel for points A and B.
Thank you.
First you load the .XLS file with _MAPATTACHDB then you link the number of Autocad point to the same field in Excel, by means of the _MAPDEFINELT command.
thank you for replying. when i did what you said, (mapdefinelt), there appears a define link template dialog box, i clicked some of the options for the key selection, but the values do not appear in the map..
sorry, i am really new to this.
After the _MAPATTACHDB command and loading your .XLS file, right click on the connection, then choose Properties:
Now you should setup the ODBC driver like this: when everything is ok, you can issue _MAPDEFINELT (I recommend you to learn these powerful commands in the F1 help)...
wow. thank you for replying..
a table same as my excel file appears,
here is a link of the task i was assigned. am i on the right track or is this possible with autocad map 3d. i was thinking of making the excel my data source, and an everyday change in values will be visible through changes in the color in my map.. just like a weather map.
http://earthobservatory.nasa.gov/GlobalMaps/view.php?d1=MYD28M
i really appreciate your help. i've been working on this for three weeks now. again thank you 🙂
or based on the data, how will i annotate the map with color, such that when assigned a value, it will automatically change color.. as for the link i attached, i will be animating the drawings so as to appear like that.. but coloring now is my only problem.
thank you 🙂
I'm afraid you can't get that.
Software GIS like Map involves links to external databases as text attributes, not as dynamic source to stylize your map in realtime.
By the way, in your spreadsheet I don't see the values A-21, A-22, C-21: how did you join Autocad objects with Excel records..?
do you mean linking the object to the excel data?? watch this video,after doing this, double click the object, properties ribbon will appear, scroll it down, then you'll see your excel data there..
http://www.youtube.com/watch?v=7D_Y2-89ySA
Dear Korina,
I link Autocad stuff to databases since '90 of the past century, so my question was about how YOU did that...
with regards to my question, i saw a video that is a probable solution, however whenever we click style editor from the analyze tab, it says "to edit style, you need to have a map layer".
does it need to be GIS, or map imported from sql or arcsde?? the map we have was previously made in corel draw and converted to dwg.. sorry for troubling you.
here's the link by the way http://www.youtube.com/watch?v=6ITZnrGfec0
Sorry, at work Youtube videos are blocked by firewall, so I can't see it.
Anyway, issue _MAPWSPACE and turn it on, then in Display Manager => NEW => LAYER
This applies to my glorious Map2006, so in your version it might be different.
what exactly do you mean by join?
i placed A-21, A-22, C-21 as texts in autocad. i just linked them by loading the excel using mapattachdb, double clicked the sheet, defined the link template, clicked the link records and selected the objects. is that it??
May you attach your Excel file?
For me, join=link...
Do you speak italian, or only spanish?
i am a filipino actually, so i can only speak english 🙂
here is my excel file...
No way, lady.
As suspected, your spreadsheet does NOT contain the A-21, A-22, C-21 values, so you cannot link automatically Acad objects to Excel records.
In XXI century, we don't join them manually one-by-one, so please feed your .XLS table with those values.
When you're done, issue the _ADEGENLINK command, and choose the "Enclosed text" linkage type.
Haha. sorry about that, i am actually a chem engineering student, and autocad is not my thing..
hope you'll reply for further more questions 🙂
