AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Autocad Civil 3D 2011 connection to ArcSDE v.10
1 REPLY 1
jlandwehr
612 Views, 1 Reply
Does anyone know if Autocad Civil 3D 2011 can connect to ArcSDE 10, or do we need a higher version? When I put in the credentials, it errors and is asking about an sde91.dll.
Any help appreciated.
Jim
Tags (1)
1 REPLY 1
nwray
in reply to: jlandwehr
Hi Jim,
I assume that Civil 3D has the same data provider limitations as Map 3D, so I don't think that you can connect to the v10 of ArcSDE.  Take a look at this post for more info:
http://forums.autodesk.com/t5/AutoCAD-Map-3D/AutoCAD-Map-3D-and-ArcGIS-10/td-p/2829619
Also, there are more general problems when connecting to any ESRI product by FDO if you are on a 64 bit system.  ESRI does not really support 64 bit, so you may not be able to connect at all if you are working from a 64 bit machine.  OS GEO has some 64 bit providers available (http://fdo.osgeo.org/content/fdo-360-downloads), but I have not heard from anyone as to whether or not they are working.
Norm
GIS Specialist
BOXX Technologies APEXX 2 2402 Workstation
Intel Core i7-6700K @ 4.4 GHz
32 GB RAM / 500 GB SSD
NVIDIA Quadro M2000 Graphics
Windows 7 Pro 64 bit C3D 2017
”Boost
