AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
AutoCad Map 3D 2012 windows installer
4 REPLIES 4
LJRogers
611 Views, 4 Replies
Just installed AutoCad Map 3D 2012 and that old annoying problem of windows installer keeps popping up when I run a different application. I've tried copying the geospatial coor. file  and renaming it to Geo...."temp"  with no success, although it did work with version 2010. Anybody got a solution for this?
Lon
4 REPLIES 4
Murph_Map
in reply to: LJRogers
Delete the other application. 🙂 Smiley Happy
Murph
Supporting the troops daily.
LJRogers
deleting other applications is not an option
Murph_Map
Log a support request with your reseller or with the subscription team.
Murph
jslonaker
in reply to: Murph_Map
I know the above problem was posted some time ago. I thought I would go ahead and post what I found to resolve it anyway. So others can see it and hopefully fix there problem too.
After copying the "Geospatial Coorinates Systems" to a temp directory. I also had the same problem of the Autocad installer continueing to be a problem. I let the installer run it's course instead of canceling it out. This seemed to resolve this issue, it no long pops up when initiating any other program.
”Boost
