AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
AutoCAD saving is not responding 64bit
0 REPLIES 0
Message 1 of 1
tint
984 Views, 0 Replies
Hi all
Computer-1
AutoCAD Map 3D 2012 32bit
4GB Ram
Computer-2
AutoCAD Map 3D 2012 64bit
8GB Ram
Everytime I open large drawings
contains 20000 BlockReferences with each block
included 40 attributes. It l take a long time to save.
AutoCAD is not responding on two computers.
First thing I would check is Options > Open and Save tab.
Look in the upper left under Save Version as.
Make sure that Maintain Visual Fidelity is turned off.
When that is turned on and you have annotative objects, it will take a long time to save.
I solved problem only on first computer 32-bit.
Computer 2 is still not responding.
I  hope someone could help me out.
Thank you in advance.
0 REPLIES 0
”Boost
