AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
AutoCAD Map 3D 2013 constant FATAL ERRORS
4 REPLIES 4
rckohler
866 Views, 4 Replies
I just downloaded a free trial & was able to import one shape file... The error occured when I tried importing a second shape file. I was able to recover the drawing once starting the program back up. As soon as it opens, the fatal error occurs again. I was unable to get anywhere after that. The imported shape files are only 1MB & 3MB's "large". I was under the impression this is a full trial version. Are there any size restrictions with it? What can I do to fix this issue?
Any help would be appreciated.
Robyn
4 REPLIES 4
Alfred.NESWADBA
in reply to: rckohler
The only restriction is the 30-day limitation, nothing else is different in functionality from the activated product.
Some questions to isolate the problem (hopefully):
  • Where do you have the SHP-data from?
  • Have you tried to use _DATACONNECT to not import, but reference the SHP-data into your current drawing?
  • What coordinate-system do you use / which coordinate-system comes the SHP from?
  • Do you have any othter product that shows these SHP without errors?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
rckohler
I added a few shp files into my drawing using Data Connect. So far, no issues.
Thank you!
Alfred.NESWADBA
does that mean that you can work now as you need?
...or is that just the confirmation for "the shape-files are ok"? (then I miss the answers to the other questions)
- alfred -
Alfred NESWADBA
rckohler
in reply to: Alfred.NESWADBA
Yes, I can work in my file as I need. The shp data is from Michigan GeoRef (MGRm). I am currently using M183-OB coordinate system (meters); which is what the shp files use.
Thanks again for the help!
”Boost
