AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
AutoCAD Map 3D 2013 Survey Points Text Floating
0 REPLIES 0
Message 1 of 1
319 Views, 0 Replies
I am using AutoCAD Map 3D 2013.  I have been collecting my own data with our TSC3 Trimble data collector, exporting to a CSV file Creating separate data stores and attaching as ASCII points.  I am able to edit them thru my style editor and all works great except that the text associated with the point is so far away from the point it gets confusing as to what point goes to what piece of text when I have several points in a small area.  Is there a way to format the text so it will be up next to the point symbol?  I know I can convert them to mtext and move them manually one at a time but I have thousands of points.  I also don't want to make my layering more complex than it already is.
Doug
0 REPLIES 0
”Boost
