AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
AutoCAD Map 3D 2012 crashing when plotting
5 REPLIES 5
staped
463 Views, 5 Replies
This is a problem that has started up in the last week.
When one of our users try to Plot, Publish or use Page Set Up, AutoCAD crashes to desktop.
No Error Codes come up.
This is happening with both new drawings or legacy drawings.
5 REPLIES 5
Alfred.NESWADBA
in reply to: staped
if I understand your situation correctly, you start AutoCAD, create a new drawing (based on an Autodesk original template), goto layout and start plot:
  • you don't get the plot-dialog and it crashes   ....or
  • you get a plot-dialog, you define your printer (which one) and then press "PLOT" and it crashes     ....or
  • you get a plot-dialog, you set up to print to DWF and then you press "PLOT" and it crashes
If you get the plot-dialog, does PREVIEW work?
Let us know the ansers to the above questions. 😉
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
antoniovinci
in reply to: staped
staped
in reply to: Alfred.NESWADBA
It crashes prior to getting to the dialog box.
Plot preview crashes it.
Page setup crashes it with a new drawing, no dialog box.
staped
in reply to: antoniovinci
We have the Service pack installed.
antoniovinci
in reply to: staped
Restart that pc, log in as administrator WITHOUT netwoking, and try to plot from Autocad: any changes?
”Boost
